Howell F & 2F Fuel Injection Kits - MUD Discount
Discussion in 'Accessories - Electronics - Recovery' started by FJ60Cam, Jan 10, 2019.
  1. FJ60Cam
    FJ60Cam Supporting Vendor SILVER Star
    9,203
    11,506
    Nov 1, 2004
    Memphis, TN
    Now offering a 'mud discount for the Howell Fuel F/2F Injection Kits. Use the code MUD50 at checkout for $50 off. Shipping is on us.
    Whether your carb needs a rebuild or you just want effortless cold starts and a more refined driving experience, fuel injection is one of the best improvements you can add.
    This kit uses the GM TBI system and mounts to the intake manifold with an adapter. The wiring harness, fuel pump block off, fuel system w/ high quality Walbro inline pump, and the computer tuned for the 2F are all included.
    Order online at: F & 2F Fuel Injection Conversion Kits
    Rusty 72, gilamonster and bkfj40 like this.
  2. FJ73Texas
    FJ73Texas
    1,153
    Media:
    9
    Albums:
    1
    944
    Aug 16, 2015
    78229
    Would this kit work for 3F as well?
  3. FJ60Cam
    9,203
    11,506
    Nov 1, 2004
    Memphis, TN
    Carbureted 3F? Does the carb have the same bolt pattern as a 2F?
  4. FJ73Texas
    FJ73Texas
    1,153
    Media:
    9
    Albums:
    1
    944
    Aug 16, 2015
    78229
    AFAIK the mounting is the same. Carb'd 3F isn't common in the US though.
  5. FJ60Cam
    9,203
    11,506
    Nov 1, 2004
    Memphis, TN
    If the displacement is within 3.9 - 4.4L and it makes less than 200 hp, I don’t see why it wouldn’t work.
    If it doesn’t, I’ll take it back!
  6. SteveH
    SteveH
    3,962
    1,277
    Jan 17, 2005
    Southern Colorado
    Very interested in the in-tank FJ40 TBI pump - here: PA Series In Tank Fuel Pump Module
    It appears you cut a new hole in the 40 tank, but will it fit an otherwise-stock FJ40 tank with the OEM baffles and sending unit?
    Thanks - Steve
  7. FJ60Cam
    9,203
    11,506
    Nov 1, 2004
    Memphis, TN
    I can confirm it will fit in a ‘69 tank. There is just enough room to dodge the baffles & float.
  8. Rusty 72
    Rusty 72
    864
    Media:
    4
    Albums:
    2
    601
    Jul 7, 2016
    Missouri
    Here is the fp module installed in a 72 tank. Had to cut the fuel pump tray down about 2". I ordered a new oem tank but with the top of the tank having ribs in it, there was no way to get it to fit.
    FJ60Cam likes this.
  9. FJ60Cam
    9,203
    11,506
    Nov 1, 2004
    Memphis, TN
    That’s right about where I had it. The silver dotted line is the outline/angle I had the tray.
    1MOA and beno like this.
  10. 1MOA
    1MOA SILVER Star
    344
    Media:
    17
    325
    Nov 7, 2017
    Warrenton VA
    How much cable is provided with the wiring harness? Or more to the point where are you mounting the ECM on a FJ40?
  11. FJ60Cam
    9,203
    11,506
    Nov 1, 2004
    Memphis, TN
    They are typically mounted in the glovebox. The wiring harness can be made longer if someone has something else in mind.
  12. SteveH
    SteveH
    3,962
    1,277
    Jan 17, 2005
    Southern Colorado
  13. FJ60Cam
    9,203
    11,506
    Nov 1, 2004
    Memphis, TN
    They are pretty quiet. You can hear a little low-tone vibration when it primes & engine hasn’t been started yet if the tank level is low. Very quiet when full. Totally masked by operating noises when the truck is running.
  14. Ace75FJ
    Ace75FJ
    10
    4
    Jan 30, 2006
    Colorado Springs
    I have this installed in my 75 and it works great. Much better power response and as a bonus it probably doubled my MPG to 14. Easy to start in cold or hot weather and at altitude in Colorado. It can become expensive but for me it was worth the price.
