How'd you torque bolts on the front driveshaft?
Discussion in '80-Series Tech' started by Rookie2, Jul 17, 2005.
  1. Rookie2
    Rookie2
    3,042
    90
    Dec 15, 2003
    Knoxville
    My torque wrench doesn't come anywhere near fitting on the nuts for the front end of the front driveshaft. So how'd you guys torque'm? Do you just have to wing it?
    Thanks,
    Rookie2
  2. Romer
    Romer fatherofdaughterofromer Moderator
    11,058
    2,677
    Sep 14, 2003
    Centennial, Colorado
    I used a smaller 3/8 deep socket with an adapter. It fit on the nuts were the standard hald inch would not
  3. NorCalDoug
    NorCalDoug problems solved daily...
    6,294
    120
    Oct 27, 2003
    uhhhh...duh...Northern CA
    I had to use an adapter as well -- got it to work though.
  4. landtank
    landtank SILVER Star
    19,455
    1,833
    Mar 27, 2003
    Groveland MA
    skipped it.
  5. snowwolfwarrior
    snowwolfwarrior
    226
    Nov 16, 2004
    Rochester kent UK
    I just tightened them up F-----G tight with a couple of ring spanners, or should I say box spanners...lol
  6. miked
    miked
    632
    2
    Mar 9, 2004
    Imperial Valley, CA
    i used a hammer and screw driver.
    each whack = about 14 ft/lbs.
  7. 4x4CPOSEADOG
    4x4CPOSEADOG
    2,588
    11
    Jul 14, 2004
    on the right coast
    I used a metric crows foot, extension, and a torque wrench. Torqued it to specified amount by the book. I don't want to mess it up and safety is paramount.
  8. Romer
    11,058
    2,677
    Sep 14, 2003
    :rolleyes: hmmm You use the hammer and drink the screwdriver?
  9. Rookie2
    Rookie2
    3,042
    90
    Dec 15, 2003
    Knoxville
    Well, thanks for the feedback guys. With the front diff flange right on the other side of the nuts, I don't see how you can get on them with a standard torque wrench. I can get in there with a box wrench and a cheater bar to get some pretty good torque on them. So I may just have to wing it.
    :beer:
    Rookie2
  10. Romer
    11,058
    2,677
    Sep 14, 2003
    I torqued two with the thinner sockets then moved the rig back a bit and did the other two. Are you saying you can't get on any of them?
  11. RavenTai
    RavenTai
    6,048
    48
    Nov 16, 2003
    Dixie co. Florida
    By hand (elbow click)
    If you use a crow’s foot make sure you either use it positioned perpendicular to the torque wrench or do the math to adjust for the longer lever arm or you will over torque them.
  12. John E Davies
    John E Davies
    922
    118
    Aug 4, 2004
    Spokane WA, USA
    I use an old 1/2 drive torque wrench, that I gutted, as a cheater bar. I slip a cut-off 14 mm box end wrench into the handle, place the wrench on the back side nuts, and then brace the whole contraption against the ground so I don't have to hang onto it.
    I use a thin walled 3/8 drive socket on a WOBBLY extension and a 1/2 drive torque wrench to reef down on the bolts/ nuts. When I have done the bottom two on each flange I roll the truck so that the next two are down, and then do those.
    It's a real PITA but I don't believe you really want those fasteners to fall off, or break due to over-torquing.
    IMHO whacking them with a big mallet is waaay too "shade tree", and just asking for trouble.
    Oh yeah - remove them one flange at a time and put anti-seize on the threads!
    John
  13. Rookie2
    Rookie2
    3,042
    90
    Dec 15, 2003
    Knoxville
    I can get on them with a closed end, or boxed end wrench, but any of the socket style wrenches (including my torque wrench) are too deep and/or wide to get on either the nut side or bolt side of the front end of the front driveshaft.
    I need a boxed end wrench with 14mm on one end and a 3/8" or 1/2" drive on the other (and then adjust the torque setting down for the added length, like Raven said). Is this the crows foot thing you all are talking about?
    Thanks,
    Rookie2
  14. miked
    miked
    632
    2
    Mar 9, 2004
    Imperial Valley, CA
    you guys know i was kidding about the hammer and screwdriver right?
    it was in reference to the method used my the prev owner to tighten the 54mm hub nuts. you could tell due to the impact marks. if i ever meet him in person, he gets a GlounkNose!
