how would one upright your rig alone?
Discussion in 'Chit-Chat' started by concretejungle, Jul 31, 2005.
  1. concretejungle
    concretejungle SILVER Star
    9,539
    757
    Oct 27, 2003
    North Cadillac
    Assuming you had a winch. I was curious if you were out wheelin' alone and accidentally laid her on her side, any tips or pics of using your winch to tip you rubber down?
  2. Liam
    Liam
    4,548
    Media:
    31
    Albums:
    4
    11
    Feb 10, 2005
    in the nappy dugout
    my rig comes upright......
  3. Chang-kuao-lo
    Chang-kuao-lo
    905
    5
    Oct 19, 2004
    Tannhauser Gate
    Very carefully.
    Better yet, don't wheel alone.
    Snatch block helps. (not that kind of snatch) :)
  4. concretejungle
    9,539
    757
    Oct 27, 2003
    North Cadillac
    You think a couple snatch blocks and hooking on to a slider would pull it over fine?
  5. Cards81fan
    Cards81fan
    103
    May 27, 2004
    Tulsa
    What about somehow hooking a strap to the roll cage and using the hi lift as a come-along to rachet it back upright?
  6. Chang-kuao-lo
    Chang-kuao-lo
    905
    5
    Oct 19, 2004
    Tannhauser Gate
    There's only one way to find out!
    "DD if i roll it i'm screwed" ha ha I hear that, man!
  7. crushers
    crushers post ho
    22,189
    188
    Feb 10, 2004
    Tara Ontario
    front bumper through a snatch block hooked to a tree and back to the top of the frame...
    block the front if you can so it doesn't just slide...
  8. Chang-kuao-lo
    Chang-kuao-lo
    905
    5
    Oct 19, 2004
    Tannhauser Gate
    tyler, that kid's got some knockers! Put that away, I'm gettin' a chubbie, now I feel dirty.
  9. Chang-kuao-lo
    Chang-kuao-lo
    905
    5
    Oct 19, 2004
    Tannhauser Gate
    sorry, that's noah's avatar, he's got titties on his elbows.
  10. Curran
    Curran
    824
    6
    Mar 27, 2003
    Frederick, MD
    Concret,
    I would not recommend hooking a winch line up to the sliders. IIRC, Wrench did that on his roll a couple of years ago and tore the slider off. They ended up hooking to the frame.
  11. Capt. Jim
    Capt. Jim
    2,200
    2,154
    May 1, 2005
    West Palm Beach, Florida
    I've pulled myself back upright several times with my own winch. Pick the correct angle to the vehicle's side and attach your snatch block. Then attach it to a point on the truck that will cause it to rotate to the upright position. You may need to use your tow strap and secure the front of your truck to a tree or other imovable object in the opposite direction of the snatch block to prevent the front end of the truck from being pulled around instead of the causing the vehicle to rotate upright. Placement of the tag end of the winch cable is critical.
    If the slider was too weak and was tore off, then it wasn't adequately attached.
  12. crushers
    crushers post ho
    22,189
    188
    Feb 10, 2004
    Tara Ontario
    i agree, if the slider is welded to the frame (or bolted properly) then it should be just as strong as the frame itself...
    cheers
  13. roscoFJ73
    roscoFJ73
    15,193
    Media:
    3
    Albums:
    1
    1,475
    Jul 22, 2003
    Perth Western Australia
    If it was a dedicated trail rig you could deflate the tyres on the low side and lever it up with a log or even better just jack it up with the hi lift
  14. crushers
    crushers post ho
    22,189
    188
    Feb 10, 2004
    Tara Ontario
    or if you are locked front and rear you could cut your tires into the ground and give er...
    i have not done this one but i have seen it done on vid...
