how to test hi lo healight floor switch?
I would guess you could get the switch from Toyota if not then www.sor.com
If the ligth change from low to high then it is working if not then it is not, If you have no lights it is probally the fuse.. I have been going to change mine to circut breaker every time I loose the lights but after replacing the fuse I forget to.
Myrle
A volt/ohm meter or continuity tester will tell you if the switch is good or not. The $17 foot switch from NAPA matches up perfectly with the older FJ-40's mounting holes.
Landcruiser Steve,
Where were you when I paid good money for a used OEM floor switch.
I bought one from MAF (I think) and the holes didn't line up. Wasn't into drilling my rig so gave it to a friend.
Would appreciate the Napa part number for future use.
Brian
ratchet said:
Do you have a part number or an application for this Napa switch?
I installed my NAPA replacement about two months ago and tossed the box (with the part # on it) that it came in. However, I've got to swing by NAPA tomorrow to pick some other stuff up, so I'll get the number for you.
Asuming that the dimmer switch for a mid-60's model FJ-40 is the same as yours, it's an Echlin # DS-101 sold by NAPA.
GP Sorensen: DS10U , the terminals are not an exact fit in my '69 but close enough, the fit in the floorboard was spot on. $11 at advance auto parts.
the Man-A-Fre replacement dimmer switch is actually a generic Painless floor dimmer switch, and, indeed, the mounting holes do not line up. Went through the same experience, cannot recommend it unless you want to drill. Claudia
I had the exact same experience - returned it :meh:
(double post from three years ago :rolleyes: :lol:)
