How to take the rattle out of stock rear tire carrier?
Moronville, ME
I've got an 82 BJ42 with a rear spare tire carrier. The top hinge rattles horribly on the smallest bumps. I'm prepping for a 6k mile trip from Maine to Utah and back and would like to fix that rattle before I head out. It's the only rattle in the vehicle that really bugs me.
I haven't taken it apart yet to see what's in the joint. I figured someone here has run into this before and can offer some suggestions.
mine rattles too, its an ongoing battle.
The "cheap fix" popular on here is to get a big hunk of rubber, like an "axe handle protector" and wedge it between the tire and the hinge, or the tub, to take up the slack in the hinges.
This didn't work for me, however, it still rattles something awful.
The hinge pins are tacked in place with a weld, they're murder to get out. DOn't both trying until you grind the weld off. I haven't bothered to jump into that yet, dreading it, really.
My '80 was the same way. The nylon bushings wear out. To install new ones you have to grind the welds off the hinges to split them. You won't get the pins out any other way. Put the new bushings on the pins,clamp the hinges back together and weld them up. No rattles.
Thanks for the suggestions. I'm going to dig into it tomorrow and see what I can figure out.
You have the late model carrier, Move the cushion that is bolted to the tub at the bottom and move it up. Or buy new, this will stop your concern.
Best,
Shane
Best,
Shane
x2, I had an extra lower bumper and mounted it on the top of the bumper. Now it presses on the amby door or Aqula tailgate and keeps the bumper from rattling.
Workie for me:meh:
Go to a hardware store and get a cane tip. Should slip right over the adjustment bolt. Works great.
Later,
I was ready to pay a machinist to make brass bushings to make it right. He told me to pound the pins out and wrap teflon tape(for pipe threads) where the plastic bushings used to be. It's worked really well for 6 or 7 years packing a 33x10.5 mud terrain. Heck of a lot cheaper. The grinding of the weld on the pin bottom was the toughest part. The weld was deep.
HTH
Don
There were no welds on mine. I assume someone along the line ground them down. It took me about 5 minutes to get my spare tire rack off.
There's no plastic bushing in my setup. There's a brass bushing the full length of the inside of the hinge.
Easy fix for me was to connect a ratchet strap to the tire and then to my passenger seat frame and crank it down. Works great if you don't have Ambulance doors. :flipoff2:
Also replacing the rubber "snubbers" and jambing a couple of pieces of folded inner tube chunks in there Does work.
Tightend up the nuts on the swing arm lubed the bolts and installed one of these. Got it out of a Grainger catalog.. No more rattles
how about a P/N please
