I ran a positive and negative wire with in-line fuse off of one battery to my stereo -- works like a champ. I even hooked up an additional light for my interior off of the same wire.
Actually the 20amp Solar is $42cad less than the 20 amp ICT (depending where you shop) The Solar converters can be wired as straight convert OR load balance if you expect intermittent 12v loads that exceed the 20amp rating. Solar converters are weather proof and thus can be mounted in the engine bay. Another bonus is that they don't look like a stereo amp and are less likely to get stolen along with the rest of your system. Yes.. I once had and ICT 20amp.. and out there somewhere is some guy trying to figure out why his subs just make a weird humming noise.
Would love to find 20amp for $42.00cad....
I am in the states and am having trouble finding them. Could you give me more info or place to contact.
Thank you
Thank you
It is dangerous to run a 12v tap off a 24v system.
Nissan did this on the Patrol for a 12v radio.
Big mistake. It cost them lots in blown batteries.
Here is good article about it. AND WORTH THE READ:
http://www.a1.nl/phomepag/markerink/12v&24v.htm
G&S cruiser parts has a good right up about 12v draws on a 24v system.
Here is the link:
http://www.gscruiserparts.com/solar.html
2 days ago I did not know this.
I went searching and found the above links.
I am glad I did.
Cheers,
Nick![]()
I just replace my 16 amp 24v to 12 v converter, pm me i'll send it to you for cheap.
