TurboDennis
So i have a truck (1997) that sat without an engine for a year and i finally found the time to put an engine in it (a good running engine that i tested myself).
With everything hooked up, it cranks but doesnt start at all. So i proceed to troubleshoot.
I know that the compression is excellent, so that's not the issue. Checked spark... - OK.
So i suspect fuel. Good.. - fuel system on these trucks is fairly easy to diagnose. Or so i thought.
1) CEL is on while cranking, so i assume the electronics are probably OK. Lots of fuel in the tank.
2) I remove the fuel return line at the junction where it connects to the main hard line that runs to the tank (near the fuel pump relay). Crank the engine, no fuel coming out.
3) In the order of likelihood i decide to completely take the controls/electronics out of equation. I disconnect the fuel pump relay and feed the connector 12v straight from the battery to run the fuel pump (completely bypassing all relays and their controls). Still almost no fuel coming out of the return hose near the fuel pump relay (just a few drops).
4) Next step is to open the feed line, to check if fuel is getting to the engine from the tank. I open the flare connection at the same junction as the return line i removed earlier (near the fuel pump relay). 12V to the pump, fuel gushing out of the the feed line. GREAT! The pump is working and fuel is getting to the engine
5) To isolate the problem area further, i remove the line from the fuel filter outlet (before it enters the fuel rail). Power the pump, fuel just dripping from the filter outlet. This pretty much narrows it down to the clogged filter. Which was odd, considering the filter was fine last time it was used.
6) Regardless, i remove the filter, and attach another used filter to the feed line that i know worked good. Power the pump, nothing changes (still just drops coming out). At this point im really starting to try and turn my brain "on". I come to the conclusion that perhaps the pump is putting out enough flow for the fuel to gush out of the fuel feed line, but no pressure, so it cant overcome the resistance of the filter. Didnt seem probable, but OK, worth a try since im running out of ideas.
7) So i proceed to remove the rear seats to access the fuel pump. Do the same thing on the parts truck (which ran great). Swap the fuel pump bracket assemblies. Hook everything up. Power the pump. Fuel dripping out of filter. WTF?!? At this point im officially out of ideas.
Anyone wants to take a stab at what the problem was? (I did figure it out later..)
