I've been searching the 80's Tech and FAQ section for the last 30-45 minutes and found lots of posts where people state they changed their thermostat, but haven't found anyone who describes the process in detail.
Can anyone point me to an existing thread that gives step by step details on how to replace on the 1FZ engine (I have a 1994), preferably with pictures? This may give away too much about my experience here, but I have zero idea of where to look for the thermostat or what I should do in addition to replacing it (other than using a new gasket when I do).
I'm currently in the process of doing a ghetto coolant flush, where I have been repeatedly draining the radiator from the petcock valve, topping off with distilled water, running till the thermostat opens, running the heater and rear heater for 15-20 minutes, turn off / cool, drain, repeat. I'm about 6 iterations into the process and the water is coming out clear (well, a tad bit milky). Upon my final drain, I will plan to fill with up to 2 gallons of Toyota Red (100%), giving me an approximate 50/50 mix of Red/Distilled Water.
Upon the suggestion of a friend of mine here on Mud, I am planning to replace the PHH (ordered the 1FZFEPHH.com silicone kit today). I suspect the PHH was replaced when the HG was done ~25K miles back and I couldn't see any bulging when I looked at the existing PHH (which had cheapy hose clamps, not the fancy constant torque clamps), but I'm figuring to just do it and be done while I'm draining the system for the last time.
Anyway, any help or guidance on how to replace the thermostat and / or suggestions on any other cooling system things I should look at / replace while I'm doing this would be appreciated.
Thanks,
Dwarf
Thanks,
Dwarf
