how to remove/replace fuel injectors
Burnet, Tx
Is it as simple as loosen fuel rail and pull the injector from the intake and then from the rail and when replacing with new rubber do you just push them on ? or is there some trick I should be doing to make sure they seat correctly
Ever get this figured out? I'm also wondering.
Pulling the whole rail will usually pull the injectors out of the intake manifold. O-ring lube is your friend. You will know instantly if you pinched or didn't completely seat the injector during reassembly.
