How to remove ignition housing from steering wheel rod?
Australia
I am currently attempting to remove the ignition housing from the steering wheel rod but um having some trouble. I've removed the u clip holding the housing in place but I still can't get it to budge. Have I missed something? Any help would be appreciated.
Ok so there a appears to be a second U clip (prt: 45201B In The diagram) inside the housing holding one of the bearings in place. Unfounded I am unsure how to remove the clip.
Is this a tilt column or not? A puller SST is required to disassemble tilt columns. I have included an excerpt from the RM183E manual, the full manual can be downloaded under the Resources tab.
45897 bolt have you removed these? all of them? I would not think that you would need to remove the clips 45201B. Maybe you need some kind of a puller?
FYI those are theft proof bolts and have to be drilled out to remove and new ones used for install.
Cheers
I'm just removing the upper bracket as shown in @AirheadNut's reply. It does appear ill need SST to compress the upper bracket and main shaft as there is a spring holding everything together.
its a tilt column, so it looks like ill have to get my hands on one of these SST's. thanks for the help mate.
