How to measure suspension lift
Discussion in '80-Series Tech' started by lumberjack, Jul 26, 2005.
  1. lumberjack
    lumberjack
    196
    3
    Feb 26, 2003
    southern Illinois
    What is the best place to measure an Fj80 to find out how much lift it has and what is the stock measurement for a 1991 Fj80.
    Thanks
  2. CreeperSleeper
    CreeperSleeper Cascade Cruisers SILVER Star
    6,865
    700
    May 16, 2005
    Forest Grove, OR
    Every lift is a little different. You could get a ballpark by measuring from the bottom of the fender to the center of the hub in the front and compare it to a stock one. Can you see a part number on the springs?
  3. LCL
    LCL
    42
    Nov 7, 2004
    Orinda, NorCal
    i guess if you want to call the natural OEM suspension a measurement of lift.. you could park on level
    ground and measure to the top of the wheel well(s)
  4. CreeperSleeper
    6,865
    700
    May 16, 2005
    Forest Grove, OR
    That wouldn't work if he had larger than stock tires.
  5. Heffenoche
    Heffenoche
    517
    1
    Dec 22, 2003
    VA
    I think bump stop to axle gives a good indication.
  6. Darwood
    Darwood
    1,957
    9
    Oct 8, 2003
    Z.O.W.I.E. Headquarters
    True, but it's not much fun to measure.
