Is there a way to disable the auto-leveling feature with AHC? There's a temporary "OFF" button on the AHC controls that would work perfectly if it stayed off. Mine always turns back on after 50mph (I assume this is a safety feature from the factory,
I thought turning off the AHC might extend the life of the AHC system by putting less wear on parts. Maybe it would help me understand if the AHC was working properly since it fires up several times on every drive to level front and rear heights. It fires up so often I'm not sure the system is holding pressure; seems the front needs to be lowered or raised at least several times on a trip to work. As much as I like AHC, and I truly do love it, I just don't need to be leveled out so frequently. In fact, I'd rather have this feature off 90% of the time and just turn it on when the conditions require it.
Preemptively, the Slee mod , yes, I am aware of it. The Slee site is pretty specific that this electronic switch works to prohibit/interfere with height control (an override to factory conditions of when to control/manage vehicle height from L-N-H). But there is nothing indicating that it also affects auto-leveling, as in the front to rear or right to left.
If you know a way to disable the auto-leveling feature or you have more info about the Slee mod, please post. Maybe we need a Slee mod #2 for AHC ... anyone have an idea of the difficulty?
