How to disable Active TRAC?
Augie is correct. Plus, you can lock only the rear and still have front traction control which allows for full turning capability. We got the best of both worlds!
Ohh, there's been times I'm glad I've had my front locker. I wouldn't go back to just ActiveTrac. The combo of rear locker and front ActiveTrac is very effective though in the tight spots where you need to turn.
4Wheeler Supply (in Phoenix) did the lockers. They did a great job. The day a 4.88 rear gear is available for the 100 I'll be back there for the swap-out.
Transmissions:
4-speed = 4.3
5-speed = 4.1
The front 4.88 gears are the same as for the 80.
The rear gear in the 100 is beefed up from the 80 to accomodate the extra power and weight. Nobody has made a new gearset for the rear. We're all waiting though!
I run 35" so a 4.88 is within 1% of my stock 4.3 with that tire size. I NEED GEARS!
