How to choose a car jump starter
Dublin CA
Although many people think buying a jump starter isn't a big deal, the reality is quite different. There are some factors you need to pay attention to before buying a portable jump starter so that you can avoid any unpleasant surprises. Buying a portable battery isn't the same as purchasing a bottle of milk; there are a ton of variables and important elements included in the equation. Here are some of the things you should pay attention to before opting for a particular model.
The power
The most important thing you need to look for is the sheer power of the unit. Manufacturers usually include "cranking" and "peak" power values.
Peak amps refer to the highest current value the starter can burst out. For example, a product with 1000 amps of peak power will deliver a thousand amps in the initial burst. However, the value drops significantly with each try. As the current decays with each attempt, it loses consistency and starts using what is known as the cranking power.
As you might assume, the cranking power refers to the stable current which can be delivered if extended cranking of the engine is required. Therefore, the cranking power is usually the more accurate representative of a particular model's capabilities.
Safety Protection
As with any other product, the safety is one of the important factors to look for. However, because you're dealing with electricity, make sure that you opt for the safest model. The things you should pay attention to are:
  • Short circuit protection
  • Over-current protection
  • Overload protection
  • Over-voltage protection
  • Overcharge protection
As you can see, every feature has an "over" prefix. It means that these units are easy to overuse if they lack protection. However, the products that have these preventive mechanisms can be left unattended without them being dangerous for the environment, and most importantly - your car's battery.
Auxiliary features
Many units have some additional features such as an air compressor or a flashlight. If you want a 2-in-1 or even 3-in-1 unit, pay close attention to these additions. People who are often on the road usually need both illumination and an air compressor for deflated tires. You can't expect a professional service out of these additional options, but they are still enough to act as a first aid. Also, if you're looking for multiple charging ports for smart phones, tablets, and more, it's a good idea to check whether the unit you've chosen can charge other devices.
Arguably the most-important safety feature for any jump-starter is REVERSE-voltage proteciton. And the power (Watts or Volt-Amps) is different from the current (Amps). I've been shopping for a more-compact replacement for a JNC660 (which is an outstanding jumper battery), and the spec I want to know first is Amp-hours (Ah, or mAh) since that's the most-useful number in judging a battery's capacity. I see the one you linked is 12Ah, which seems very small. And it says it can only crank a 3.5L gas or 2L diesel engine. I've never encountered a diesel that small, and neither of my gas vehicles has such a tiny engine. Do you know where I can get one that's rated for a 5.8L gas or 7.3L diesel?
But no matter what I'm looking for, durability & warranty are major considerations, and you didn't mention them. Since I've never heard of the company in your link (whom I assume you represent), and warranty isn't mentioned on that page, I don't think I'd ever consider buying that brand, or from that site. If I buy something that cheap on Amazon, at least Amazon warrants it & handles the return. Do you have an Amazon store? Or does someone else on Amazon sell that brand?
