"An externally regulated alternator can be activated to full output by connecting a jumper from a strong battery to the 'field' terminal of the alternator. You should HEAR the alternator working. If you don't hear it and you're sure you connected to the field correctly then the alternator isn't putting out."
Honk wrote this recently in another thread of mine........someone please explain in a little more detail as to how this is done. Do you disconnect the volt reg ?
Do you disconnect the F terminal ? Just need a little more information to see if my problem is my volt reg...everything else has been tested and is ok.
Thanks.......Mike
Thanks.......Mike
