Any DTC codes stored after the attempt?
I'm not quite familiar with Techsteam menus and features. but I'll look into some online resources and check that, too.
Sounds like you have the ZPC process down...at least you will be able to revert it back to normal.
The CC switches is wired directly to the Skid Control ECU (Master Cylinder). So I don't see the air suspension switch should have any affect.
Can you check the connector to the Skid ECU to see if it has the 4 wires for the CC switch?
Going cave man style, you can try just using the jumper wire method mentioned earlier in this thread?
I wonder if going simpler might do the trick?
Yep, that's what I was referring to. Sorry to hear your port is a different configuration.Do you mean the "paper clip ZPC reset" method? The OBD port is different from previous versions. It has only 6 pins. I don't know how to figure out which pins are the CG and TS.
Have you thought about running temp wires with probes of some kind to the non terminated connections used by crawl and MTS on the skid control ECU? It could confirm if it is just wires missing or logic is also not there as well.
I'm very interested in getting CC/MTS working on my 2020 GX460. I mistakenly purchased the parts for the 2019 thinking they would work on a 2020. Then I found this thread and realized that there are significant changes to the 2020. I had the 2019 CC/MTS switch panel but sold it in new condition... The switch 2019 CC switch is a different type than the 2020 switch, plus with the changes outlined in the wiring diagram, I was certain it would not work.
I purchased the 4 switch panel for the 2020 Luxury model with CC/MTS and air/dynamic suspension switches. It's still wrapped up new... I was hoping just the switch was needed, but again, it looks like some additional mods will be required.
I happened to find this 2 switch panel from a 2020 Premium model that was sold overseas in the UAE that is called the GX460 Off Road Edition. It does not have all the additional options that are included in the US version of the GX460 Luxury with Off Road Package.
Hopefully somebody will be able to help find the part number. It also give me a little hope that it will be possible to add CC/MTS to a 2020 Premium.
Here is a link to the YouTube video of the GX460 Premium with Off Road Edition that is sold overseas...
Being an R&D engineer, I might try doing various combinations jumpers, but again, that could prove fatal to the electrical system/computer.
Are any of the wires the same color as the earlier models? Perhaps that could reduce the guess work??
Just be careful my friend not to fry anything.
ctors
I'm thinking about finding a fully-wired ECU connector for replacing/testing. Don't know the part number, though. Might be the same as 2019 model, can anyone share a picture from their skid ecu connector of 2014-2019 model? Also, the skid ecu part number?
I'm still learning... But I'm guessing the change to the 2020 is due to TSS/Dynamic Cruise Control becoming standard equipment. Do you think there is a difference between the wiring on a 2019 Premium vs the 2019 Luxury with Dynamic Support Package? Does a 2019 Luxury with the Dynamic Support Package still use the under-dash CC/MTS module or is the switch wired directly to the Skid ECU? I'm just trying to understand why such a change would be made near the end of the vehicle production run.
All 10-19 models regardless of options use the same MTS module swap. 10-13 uses a different model rev than the 14-19 models. Dynamic cruise from 10-19 hasn't made a difference in what vehicle can take the mod.
