If you are not equipped or are no longer running AVS/RAHC the following switch has been confirmed by GXOR member to enable crawl.
PN: 84970-60090
Place vehicle in 4L and press the ON/OFF button above the SPEED toggle. You can still brake and when you release it will keep going. Pressing ON/OFF again cancels. Or stopping and going to 4H
DAC is just a neutered downhill crawl control at a fixed rate (~2.5 MPH IIRC) and only controls the brakes and not the accelerator.
Crawl can control both accelerator and brakes, is multi-speed (~1-5MPH) and works uphill/downhill
DAC only function is removed since the multi-speed crawl downhill is a better implementation IMO.
MTS also offers up different ABS "Braking" algorithms while off-road
View attachment 2116907View attachment 2116908View attachment 2116909View attachment 2116910
