how strong are stock 74 spring shackles?
:) thanks
Its an ambiguous question ,one that could be answered with "how long is a piece of string?"
Its obvious the components of a landcruiser are fully tested to a standard that wont let the rest of the vehicle down.
I would guess that by the time you are getting shackle damage you would be also getting bent diffs,cracks in the frame and broken mounts.
how about if we compare stock shackles to after market?
Which ones?:D Some are better ,some are worse. The Beltons I have on my 73 were cheap but they have lasted ok.
Hey Gold Boy, the stock shackles on the 4 cruisers I've owned (one in springover configuration) have held up fine. Nonetheless, I'm going to 3/8" thick anti-inversion when funds allow (pins on the rear of my JDM were seriously corroded/pitted when I did the bushings). Where in the Southern interior are you at...I'm in Greenwood.
:beer:
I purchased a set of Anti-inversion shackles from Sprung Art out of Australia. They look to be the best quality I have seen yet. I compared them wiht the same style, other make on the shelf at a local 4X shop and they were heavier built and have protected grease nipples. I am still gathering parts before I install them so I can't tell you how they perform...
