How old is too old?
dnp
Supporting Vendor
Jackson, MS
Following the purchase of my new FZJ80 (thanks to those of you who helped clear up my question about the different designations), I have begun to investigate the possibility of a supercharger. With that said, at what engine age would it be a good idea to put aside the idea of a blower? With 91K on the clock, is that too old to consider a stress-inducing add-on like a SC?
Thanks for your input........
dnp
You may want to search the archives specifically for posts from Christo and Robbie. They posted several things that need to be evaluated, such as injectors, cooling system etc before you do it.
The mileage is important, but not as important as the condition of the truck.
Before you get slammed by someone else... use the search. This topic has been beaten senseless. Have your local Toyota Dealer check out the engine and see if they say the engine is a good "donor" for the s/c.
[quote author=Sammy Jenkins link=board=2;threadid=15819;start=msg150711#msg150711 date=1083726782]
[/quote]
They won't have a clue. I have talked to 3 separate dealers about the s/c and none of them had ever done an install or seen the s/c in person. I wouldn't trust a dealer to tell you whether or not your truck is in a condition to recieve a s/c. Just my 2 cents.
New radiator, hoses, thermostat, water pump, fan clutch, send out fuel injectors for cleaning, rebuilding, flow testing, replace egr valve, vsv, modulater, clean carbon out of intake system, set timing, check & adjust as necessary valve clearances, check compression. Then consider installing supercharger, along with egt and boost gauges. At least, that is what I would do if I were going to install a supercharger on a 90K mile truck.
The Toyota Dealer by me has their own TRD section there, where they just install TRD parts.
[quote author=Sammy Jenkins link=board=2;threadid=15819;start=msg150891#msg150891 date=1083763157]
[/quote]
WOW, I hope they don't charge an arm and a leg to install those TRD parts;
TRD emblem
TRD oil cap
TRD rad cap
TRD sticker
TRD hat
TRD shirt
TRD air filter
TRD coat
TRD etc.
