How much weight can a Kaymar swingout carry?
SoCal
Website
www.adventurebuddies.com
I did a search and found various tidbits but nothing definitive. My right swingout has a 315 AT tire plus the 48" highlift so I figure that's around 100 lbs or so. I don't know how much the tire/wheel weighs. I have often stood on top of the tire (in the closed position of course) and it seems totally sturdy.
I'm thinking of modding the other swingout to hold a lockable storage box which will contain 2 jerry cans and a 2.5 gallon propane tank and a few odds and ends. The jerry cans and propane weigh about 100 lbs plus 30 for the storage box plus some other stuff for a total of about 150 lbs. I got the idea from this sportsmobile. Any thoughts?
Well, we have dual 33" spares with hi-lift and shovel. Would be comparable to the weight your talking about.
Before that i had a single 33" spare with hi-lift, 5 gallon NATO can and a c02 tank.
No problems with the weight and we even pull a trailer behind it. Bumper has yet to rip off :D
no idea what the official specs are on the swingout.
However, it sure looks to me like the spindle is comparable or bigger than some I've seen on trailers that should have axles in the 2000+ lbs range. Now the lever arm on the Kaymar spindle is longer, obviously, but it still looks to me it should be able to handle a couple hundred lbs at least on the arm, likely quite a bit more. I've climbed on the spare tire of mine with no apparent ill effect.
That spindle is a good chunk of metal and welded top and bottom.
The arm looks pretty sturdy too.
150 lbs should be no problem IMHO.
You guys are both confirming what I already suspected - Thanks for the feedback. Now I just have to decided whether to build the box or buy one with the right dimensions and then weld it to the swing arm...
I'm sure lots of folks here would be interested in seeing that fab job in pics. Please document as much as possible. TIA.
