any 200hp 4.3's out there.
in a 40
is the driveablility good?
enough torque?
in a 40
enough torque?
Howdy! Very true. An awful lot of stock engines have got an awful lot of awful places. If your going to be blasting thru soft sand, snow, and mud, then you will find that a lot of horsepower and rpm is good. If you are looking more at crawling over rocks and stumps, then low rpm and bottom end torque is nice to have. When I am in the rocks, I try to use the right pedal without using the clutch. I spend a lot of time under 1000 rpm, and yes that is with a 350. Compression ratios of 9:1 or less, and small throttle assemblies seen to help in this area. It's pretty hard to dial in both Hot Rod and Truck type performance on the same engine/setup. John135hp is enough. Hard to say what is enough. Everyone has their limits. I would personally think 300 would be the limit for me. At some point it's just not going to be driveable. I would think torque would be more important than HP.
All depends on your driving style, drivetrain, and how much crap you have bolted or welded on. IMO
For those of you that are gonna say the 4.3 doesnt give you the same torque at low end. The second tcase makes that a useless argument.
Howdy! The "drivability" on the street would probably be better than an F/2F due to the increase in power. I guess "trailability" is moot, now that you happen to mention the double transfer case setup. The V8 is 5" shorter than the F/2F, the V6 is 5" shorter than the V8, and a 22RE is 5" shorter than the V6, so you could have the room for 3 transfer cases, I suppose. Your question may not ever get the answer your looking for, as I can only remember ONE poster that has completed the 4.3 setup. Unfortunately, I don't remember who it was. I personally like the 4.3. I hope to transplant the one in my wife's 98 Astro van into my 85 mini truck someday. That has been a very popular swap, but putting the 4.3 into an FJ40/45/55 has not been. Hopefully, you will get a response from someone with hands on experience with this arrangement. Good Luck. Johnwith the sm420 i have in the garage and 2 transfer cases the rpm the torque is developed is not a concern.
my buddy has a truggie
with 2.2 liter 4 banger the stock Tcase and a 4.7 marlin case
and 35's with 4.88s and he can climb a tree.
with #'s like this and similar weight.
By 1990 the 22R was producing 108 hp (81 kW) at 5000 rpm and 138 ft·lbf (187 N·m) at 3400 rpm.
I probably should of used a different Title.
the F engine is a 3.9 liter, 75/93 kW (105/125 hp), carburated gasoline engine that is capable of 261/289 N·m (189/209 ft·lbf)
Power output of the new LU3/LG3 engines is 180-200 hp (134-150 kW) and 245-260 ft·lb (332-353 N·m).
The 4.3 is a
.6 increase in hp
.24 increase in torque.
on paper it looks pretty good to me. even more so since its 5" shorter than a small block. that leaves room for 2nd Tcase. in the same space as a Small block.
