- Thread starter
- #21
You should be using the same grease on the trunion bearings as in the knuckle because it is in the same place and you don't want to be mixing greases
turbocruiser, that's some great pictures. I will use his post 7 and 8 to clearify the number of tubes needed. I follow exactly was he does but I have to ask why he did not put grease on the trunion bearing races in his first picture? I then pack the axle cup FULL of grease after I slide the axle back in but before I put the housing on. Then if you look at his final picture in post 8 when the steering housing is back on, I pack as much as possible into the housing until its between the top set of holes and the next ones down. That is the 3/4 full that the FSM is talking about. After I bolt the spindle on I go ahead and pump a few pumps in through the fill plug. I do this because you cannot fully pack the housing 3/4 with the spindle is off, otherwise the grease falls out. And this all takes nearly 4 tubs of 14 oz grease.
The FSM calls out wheel bearing grease for the trunion bearings - which is what I used. I don't think there is much chance of the wheel bearing grease from the trunions mixing with the moly from the knuckle/birf.
Tom
I agree that the two greases will eventually mix but nothing to worry about. The trunion bearing only rotates a limited amount, not constant spinning like a wheel bearing. Due to this fact I think using moly grease is a better choice even when the FSM calls for non moly grease because the limited motion of the bearing. Moly is used in sliding applications and typically not good for a bearing roller that should spin but again the trunion bearing is unique.
