I have a leak between the transfer case and trans and would like to pull the transfer case without pulling the trans to investigate. I can only identify three bolts that go all the way through. Much appreciate any comments.
Search for Coolerman here on 'Mud. In his signature line, there's a link to his website. Scroll down to the transfer case rebuild.I have a leak between the transfer case and trans and would like to pull the transfer case without pulling the trans to investigate. I can only identify three bolts that go all the way through. Much appreciate any comments.
Thanks so much. Will do.Search for Coolerman here on 'Mud. In his signature line, there's a link to his website. Scroll down to the transfer case rebuild.
Thanks so much@76classic
Actually, Coolerman's instructions for locating the five bolts are located in the item "Drivetrain, converting to 4 speed from 3 speed transmission" or something to that effect.
To simplify, see the following link:
Pictures 7 and 8.
True statement. Use a puller, do try to beat or pry the t-case off. Beating on either to separate them can mess up bearings and synchro rings in the transmission. A home made puller will work fine, and some examples are floating around here on 'mud.Sometimes it can be really hard to separate a t case from the transmission.
