How is your Aussie locker holding up?
Durango, Colorado
Website
www.durangomagazine.com
For all of you who have installed Aussie lockers how are they holding up? Would you do it again?
I'm thinking of ordering one soon for my daily driver. I know a selectable would be better but unless a toyota electric locker falls out of a tree the price on the Aussie is making my decison.
I thought I have read a few places that you can't run the fj80 e-locker in the sf rear? That it only works with the front because theres not room for the axle clips or something. No? If you had a ff rear axle, then you would be okay.
-Dustin
Shoot you have me on that, I forgot about that. The 3rd would bolt up though with some minor mods, you would have to figure out a c-clip situation. In the front, where no c clips required they are fine. It is different for mini trucks as well because they don't have c clips either. Damn c clips...
just got mine from the ups guy at noon today and am stoked to intsall it and test it. i will keep you updated.
EDIT---Not the bling or as nice as the cable lockers in my BJ74...but I wanted to see what lunchbox lockers are all about, so Das Poo Vagon now graces then front and rear END EDIT...
They have not been in long. It was twitchy, and banged every once in awhile...then I went wheeling, aired down, and after wheeling aired up at a fuel station a short while after the trail. It drives night and day now. Moral of the story is make sure your air pressures are even. I forgot to check my air pressure after I swapped the axles in (dohhh) and figured being twitchy was just part of it.
You do need to take the load off and coast around tight corners when going slow (parking lots, into stalls etc). You will hear it ratchet in this situation.
I don't mind driving it at all, after learning what to do and what not to do. My girlfriend does mind, so she does not.
Make sure your spacing is correct.
I have not had them in long enough and seen enough situations to say if I would do it again...Other then that, I have been pleasantly impressed (now that the pressures are right). Of course I've not gone through a winter with it...
gb
I loved the one in my rear axle so much that I had to buy one to put in the front.
Anyone running one in the rear of an 80 Series?? How hard are they to set up??
CruisinGA said:
Autolockers like the Aussie will loosen up the studs on FF- just not a real good idea.
I talked with Bill at Aussie Locker about this, and he said he had heard no complaints.
I will let you know what I think of it next week when I'm done with my aussie/FF swap and put 1000 miles on it this comming weekend.
I have had mine about 8 months with no complaints and no issues.
what was the gap between the gears, did anyone use a feeler gauge and measure and replace thrust washers as well or did you just throw it in and go?
