The 80 series has a mechanical lspv - what does the 100 series do? How does it work with lifts etc?
Ok. So its a fixed proportioning? Seems like the failure mode is no brake pressure to the rear, based on the fsm?I'm pretty sure the 100 doesn't have a mechanical lspv, since all model years came with ABS. So, no need to mess with anything in the breaking system after a lift, ABS has got your back
Like without booster pressureI guess you could call the proportioning fixed? The ABS system measures wheel speed and sense sa wheel locking up, then opens valves to reduce braking at that specific wheel. I guess you can just think of ABS as a really sophisticated lspv system?
Failure mode of what? The entire braking system? Or the ABS system itself?
Other than wheel speed sensors, what data does the computer use?For 98 & 99 models it is similar to the 80 with a mechanical lspv (for those years part # 47910-60120). 98 & 99s might need some adjustment of the mechanical LSPV after a lift.
In 2000 and later, along with adding separate lines to rear brakes, VSC, and ATRAC the proportioning is done electronically. With individual control of each brake and ABS sensors the brake computers can figure out the correct proportioning. This system is independent of lift so it does not need readjustment. It is not fixed proportioning, as the computer is making continuous proportioning adjustments based on its sensors, which is how it deals with load and road variations.
So how does it know if youre towing a trailer other than "brake till it skids" ??Know 2000+ has a deceleration sensor and a yaw sensor. The deceleration sensor is used for normal braking. The yaw sensor could be used for normal operation, but may only be used for VSC operation of the brakes.
Is anyone else's 99 only wearing the front pads and not the rears? I've changed the front pads and rotors but never the rears since factory.
I think that Electronic Brakeforce Distribution actually helps with the wear since it puts more braking force on the rear compared to mine but the problem is that the 99's don't have Electronic Brakeforce Distribution.There is no solution needed because there is no problem. Electronic Brakeforce Distribution (EBD) maximizes every wheel's brake power. If the sole goal was to have all pads wear at the same rate, they would simply make the rear pads, much, much smaller. The percentage of brake force between front and rear does vary.... according to weight, center of gravity, driving style, terrain, etc.
Hmm, interesting. I didn't know about that. I'll still need to find a solution for this problem but it can wait for a while.I believe the term EBD was coined after 98-99 but I still think the early 100's have some form of EBD, except it only has 3 channels, not 4, as the rears are considered one.
