How do these hubs sound? (1 Viewer)
Hard to tell what’s brake lining noise or hub. What are you concerned about? Unless your bearings are completely screwed, you won’t notice much. Are they loose when you hold 12-6 on the rotor and push/pull? You also have noise from the CV’s to contend with, not to mention the radio in the background haha.
Are you worried about the wheel bearings being loose, or about the wheel bearings starting to groove into the races?
Pass side makes some screaching noice. Did you try to remove the brake pads and spin? What do you hear?
