How do Lockers work?
Romer
fatherofdaughterofromer
Moderator
Centennial, Colorado
I know there are all kinds of different lockers out there, and I know it helps you wheeling when one wheel is in the air maintain traction on the other wheel. Being an engineer, I need to understand how things work. Before I go off and reserach what kind of locker to get, I am trying to figure out in my mind how they work.
This is probably a newbie question, but mechanically how do the lockers work? Trying to picture how they keep traction on two wheels or one depending on the situation.
Thanks,
Ken
its magic ;)
I'm sure someone will have a more technical description as I'm not an engineer, but I seem to have some of the tendencies...
I assume you mean auto-lockers like a LockRight, Detroit, EZLocker, Aussie Locker, etc. I'll also assume you understand how an open differential functions when dividing the torque between 2 axles.
This is how I understand my LockRight; the Detroit is similar but it replaces the whole carrier.
The side gears on the axle shafts go away along with the spider gears. The pinion gear still turns the ring gear, which is attached to the carrier which has the pinion shaft (that the spider gears used to ride on) running through it. The pinion shaft drives two driver gears (one for each side), which mate to splined couplers on the ends of the axle shafts.
This picture http://molmed.umassmed.edu/~kdb/locker/lock028.jpg shows the two driver gears in the middle of the carrier and the couplers toward the outside. You can also see the hole through the drivers that the pinion shaft will go through. Circled is a bias spring which puts tension on (1 of the 4) stop pins that align the drivers and keep the couplers engaged.
Under normal circumstances, the springs keep the drivers and couplers locked together so both wheels are driven with equal torque. **this is where the conjecture starts** The holes in the drivers that the 'stop pins' sit in are flared at one end allowing the pin to tilt such that if one of the couplers is rotated faster than it's driver gear by an outside force (being the outside tire in a turn), the spring tension that held the driver and coupler gears meshed is decreased, and the teeth separate a bit allowing that side to 'ratchet', simulating differentiation. The locker will only allow 1 side to ratchet at any given time because there is only enough room in the carrier for one side to separate.
Also, the 'ratcheting' only occurs in the driven direction, which I think is due to the fact that the stop pin holes are slotted away from perpendicular in just one direction. I wish I understood this a little better since it works just as well in reverse or under compression braking and I can't seem to wrap my brain around the whole deal.
So, the short answer is "it's magic". :)
Landpimp said:
its magic ;)
Thanks John :flipoff2:
I'll look those sites over and see if it answers my questions. Appreciate it.
Desretdude and e rock. Thanks. The sites with the description made it really clear
Woody should link that sire to the Tech Links. The sites shown there showed How to put one on not what it did.
Thanks
Any recommendations on an inexpesnive rear locker?
I bought my LockRight slightly used for $75 I think. I'm still running the stock 10-spline early rear shafts, and I happened to get lucky and find someone who had upgraded to fine spline rear shafts.
The first time I got it offroad, I fell in love with the new traction. Between the locker and the sm420 I just put in, I go places in 2H that weren't possible in 4L before.
That said, if you're looking at an autolocker anyway, I don't really see any reason not to weld up the rear. My LR is very predictable and pretty mellow on the street, but for the cost, functionality, and simplicity I vote for welding. If cost is the primary concern, welding is probably the cheapest, but not reversible. Then probably Aussie Locker, but they might be backordered? You might be able to find a used one if you ask around enough, but they don't seem to come up very often.
I'm at a crucial decision point myself (and it's somewhat related). I don't want to keep my stock front axle very long, so I don't want to put any time or money into it. But it's leaking from between the housing and the third member. I have a new gasket for the third and a new set for the knuckles, but I'm not sure if I want to invest the time or not. If I do, I'll probably just swap the thirds front and rear so the LR is in front and then I'll just weld up the other for the rear. The problem is that there are several other projects ahead of the SOA with disks project (when I plan on getting rid of the front) - mainly the TBI 2F that's sitting under my workbench that I plan on doing this winter.
So far my solution has been to park over a folded rag...
as a vehicle that gets a lot of street use, i disagree. welded is fine for off road use, but turning is quirky on pavement and gets annoying.
I have only a little bit of time driving a truck with a rear spool on the road, but I found it to be more predictable (disclaimer: it was a bit longer wheelbase than a 40). Sure, the tires chirp and you notice the 'push' around corners, but you expect that and there's no quirky "ratchet - pop" or unexpected unlocking on the freeway. I guess it just boils down to what you're willing to tolerate. I like to pretend that I'm young enough that the sm420 gear whine and slow-as-hell shifting don't bother me either even though it's my DD. After all, isn't that why God invented Alpines and 6x9s? :)
Lockrite so-slip was a very easy install, something you could handle easily judging from your other posts/engine "features."
I posted a detailed, pictured "how to" string a while ago, but I had to delete the attached pics in order to post other images for other strings.
I just fininshed 1 coat of 3 POR-15 yesterday, so it still isnt on the road and I don't have my driving impressions yet..
Thanks John, do you have a manufacturers link to what you are talking about?
Ken,
Here's the manufacturer's link, pick "Application" and other links on the left to view installation and other information. It was very clear and easy, with the exception of the order the c-clip needs to be installed, but ask me that again right before you install and I'll explain.
http://www.powertrax.com/noslip.html
I got mine from Tellico4x4.com for about 250, which was the best price I could find for the no-slip.
john
Not to plug Aussie locker, but i got mine for 260 shipped. And it works great so just to let you know there are other options out there.
So, whats the pros and cons for the no slip. Also, the Aussie. I am new to Lockers, don't know anything more than I learned in this thread. Except the ARBs cost almost $1K, too expensive. The less than $300 seems about right to me.
Thanks,
Ken
I don't have driving experience with either, but the designs are almost identical. I considered the Aussie, but there were lots of people having problems getting their orders filled so I shied away from them. Many people are waiting long periods of time to get theirs.
I opted for LockRite No-slip due to the fast shipping and availability for exchange/service here in the US if I have any problems. Plus, go All-Blacks!
The no-slip is supposed to be a marginally improved design over the Lock Rite, by the same company.
I've driven mine with a lock-right in it as a DD for a long time. It worked great and would use another one in a heart beat. It had a little bit of quirky handling, but once you get use to it, it is very predictible. I have since moved my Lock-right to the front and welded my rear diff. If I'm running more than 20psi in my rear tires they slip enough that I can turn sharp on blacktop. If they are less in pressure, the tires get more traction and tend to chirp when turning sharp. Both setups are very predictible once you get them in and drive it a little. If I had the money I would have put another lock-right in the back, but trail duties and cost turned me to welding.
Chris
welded rears eat tires on the street,while being predictable,you end up paying for it in tires.
the way i see it if you learn how your locker works then it becomes very predictable.the aussie locker is predictable and doesnt throw you in another lane when it does engage/disengage.also its cheap and pretty tough.
ken just go with the aussie.
shawn
OK, I am looking at these and sent an e-mail requesting a qoute. There is a whole thread in the general for sale section on Pirate on these. Anyone here try these?
https://offroadlockers.com/howitworks.html
I have the rearend in my 40 welded and its been like that for a few years. I DD 15+ miles a day and will be driving it 300+ miles to college. The only time I notice its welded is in a parking lot...and maybe its because I'm a kid but thats fun. If you don't like the chirping like me, then air the tires up a bit more. The only time I've noticed the rear end slide around on a turn was when I punched it...I hadn't had the 350 for long :D . That would of happend with a lunchbox locker in the rear too. As far as tire wear. What type are you running? I'm running BFG MTs and rotate them a little more often but with their harder tread, tread wear isen't very noticable at all. The softer swampers and similar tires will notice the wear more I'm sure. Welding the rear end is so cheap and easy, jsut try it out and if you don't like it through in a lunchbox or selectable locker.
Joseph
