how do I remove the middle seats?
Discussion in '80-Series Tech' started by jonb96150, Jul 11, 2005.
  1. jonb96150
    jonb96150
    709
    Media:
    3
    Albums:
    1
    5
    May 3, 2003
    S. Lake Tahoe, CA
    I don't have an fsm yet, or even an owners manual, (both on order) and I am unsure on how to remove the middle seats from my 97 (already removed the 3rd row). It looks like I fold the seats up, pry up the plastic cover at the hinge/floorboard and there is a bolt that needs removing. Is that all, or is there another bolt lurking somewhere?
    Thanks for any advice! I tried searching but was too ignorant to use the correct search phrase.
    JonB
  2. AMMO
    AMMO
    1,843
    739
    Feb 4, 2004
    Lincoln, CA
    Look for the lever my son.... Look for the lever.... on the side of the seat.
    -A
  3. firetruck41
    firetruck41
    5,732
    34
    Mar 27, 2003
    Camas, WA USA
    Looks like he's already figured out how to fold and roll the middle row, just wants to know how to remove them.
    I think you just need to remove those bolts that are under the plastic covers, I don't think the middle row seats were really meant to be "removeable", so you do have to remove the bolts.
  4. nyk438
    nyk438
    253
    Jun 23, 2005
    Austin, TX
    There should be bots on the front of the middle seats undo em.
  5. dfmorse
    dfmorse
    1,518
    2
    Jul 7, 2004
    EVERGREEN, CO, USA
    Pop the plastic and unbolt each seat; 4 bolts per seat. Re installing is a bit of a pita but doable...
  6. reffug
    reffug
    3,925
    11
    May 28, 2004
    'in dat der briar patch'
    4 bolts each as previously stated. Basically a piece of cake. Reinstall isn't that bad either just remember to reinstall with the seats in the kicked up position and after you have both back bolts started then lean the seats back slightly and get the fronts started as well. After that just torque down nice and firm.
  7. jonb96150
    jonb96150
    709
    Media:
    3
    Albums:
    1
    5
    May 3, 2003
    S. Lake Tahoe, CA
    Thanks everybody:cheers:. I am looking forward to the day I can answer a question rather than always posting a question!
  8. NorCalDoug
    NorCalDoug problems solved daily...
    6,294
    120
    Oct 27, 2003
    uhhhh...duh...Northern CA
    Yes, it does help to have the seat up when reinstalling. The tough part of the reinstall is getting the bolt threaded correctly.
  9. reffug
    reffug
    3,925
    11
    May 28, 2004
    Yes I learned this the hard way............... :doh: When doing the fuel pump mod for my truck and if you try it the other way it can be a real bogger to get the bolts rethreaded correctly. Oh well chalk it up to experience. :cool:
