How do I install the OEM roof rack on a US truck
I just got a OEM roof rack from another cruiser and it is direct screw in. Should I just line it up and drill the holes, and if so what should I use for anchors once the holes are drilled? Or is there some better way?
racks
Well, I can't really answer your question, but I think you'll probably get some replies asking you why you want to do such a thing.
I also have a feeling folks will suggest a gutter-mounted, removable rack, instead of OEM, for a variety of reasons.
Andy
Andy
I would agree to put a gutter mount rack. Why put holes in your metal if you dont have to. Where i live holes = rust.
You can buy a complete rack system (yakama/Thule) for around $200.
http://www.thuleracks.com/thule/fg_vehicle.asp (these are the gutter mounts for a LC)
There isn't an OE roof rack. There are dealer installed POS racks on top of many US FJ60s. They are useless and should be avoided like the plague. What do you want to use the rack for anyhow?
YUP, I agree 110%
Wrong!! ALL Canadian '60 series trucks came with FACTORY roof racks installed.
I've got me some nice gutter mount racks laying around my garage somewhere, that I picked up for likle $50 many years ago, I think they are Thule's. I'll need to dig them out once I find me a nice Fj60. They worked nice on my old truck, when I need to carry a Canoe.
81-86 shows a OEM roof rack for the US.
interesting, the actaully roof if it had a roof rack came pre drilled for the rack, with the captive nuts.
I have never seen one on a US 60-2
I have seen the chrome racks on the CDN 60-2's....I assumed they were dealer or port installed
I just had the diagram faxed to me and can post it tonight if anyone cares
Captive nuts in the roof on both BJ60's that I've had. DEFINITELY not dealer or port installed. I've NEVER seen a Canadian truck without a factory rack unless the owner pulled off the factory rack and then you can see the holes or the screws in the holes.
Hmm... Toyota does do some screwy stuff. I've got a grid of bondo plugs on my roof from the sheet metal screws. Got a picture of the Canadian rack installed? Is it as lame as the US ones?
Peter S.
To answer your question about mounting them to your roof. I would buy some plus nuts from a yakima dealer and make sure you use a high quality silicone to dab in the holes before you tighten down the plus nuts. Once they are installed you will have a threaded watertight hole proveded you used silicone on the bolt threads. Also, if for some reason you don't want to use a raingutter rack, look at their track systems. They allow you to utilize any of their accesorries and have a clean look. Oh yeah, if you drill make sure your not boring into any support structure or you may be sorry. Good luck!
Not to hijack this thread, but I just acquired a 1982 FJ 60 that I thought didn't have a roof rack. Only after I bought it did I noticed it had holes drilled in the roof. What to do now? I bought an OEM rack from a guy that was parting out a 60 on this board. (Mark are you reading this?) I guess I thought I should put it back up there because of the holes. Now I'm having second thoughts especially after reading they're useless POSs. So how do I fix the holes short of body putty and repaint? I've got silicone in them now. Seems like a PITA to have to go back and resilicone every so often.
They aren't meant to carry heavy loads. I think the labelling says 150 lbs max. They do provide a place to tie down lighter loads on the roof but when carrying something heavy (like a canoe) use a gutter mount rack.
that looks like the parts diagram I have of the OEM roof rack........I have a feeling that only the canadians got stuck with those ;)
ridgerunner said:
They're not quite as useless as everybody seems to think. They *did* come from the factory on every Canadian spec 60. I have carried the occasional load on the roof including three canoes on one trip and eight or ten wheels another time. I've never thought it worth the bother to build or buy something better.
I like the fact that anything you do carry is away from the side of the rig where it'll get yanked off by trees.
paulj- Why not just thread some bolts into the hard points. Just dab your silicone on the threads and tighten down. You could even paint the bolts to match. Seems like a lot less work than filling them and I bet you would really have to look to notice from the ground.
I have found the roof is easily dented when you load up on the factory rack, It needs some form of base. other than that they seem pretty solid.
