hi. i'm picking thru my stock 76 fj40 ignition trying to get the beast to start and have found a ton of useful info here so far. but i can't figure out where the ground is located for my distributor so i can check if it is ok. also, where is the ignitor located?
i have a good strong spark coming from the dist end of the ht wire when i bridge the points with a screwdriver with the ignition on. but there is no spark at the plugs. i've replaced the condensor, points, cap, rotor, plugs and wires. i've checked and cleaned all connections but still no luck... hoping its a grounding issue somewhere. after that i'll check on timing in case the dist somehow moved while i was farting around in there.
thanks.
thanks.
