How Deep To Cut ?
Discussion in '40- & 55-Series Tech' started by KS, Mar 3, 2004.
  1. KS
    KS
    31
    May 9, 2003
    Iam in the middle of the cut and turn for a SOA on my 72 40. Can someone tell me hod deep to cut. I cannot see a line or any difference in the cut yet and seems like I should be deep enough. Thanks
  2. woody
    woody unhelpful spotter Staff Member Admin
    10,831
    Media:
    317
    Albums:
    8
    2,573
    Jan 15, 2002
    Toquerville UT
  3. Isotel
    Isotel
    4,061
    Media:
    5
    Albums:
    1
    39
    Sep 29, 2003
    Crawlorado.com
    1/4 inch.. you should see the line where the inner and outer tubes meet once you go deep enughf... i know where you are at, just keep truckin and it will all be cool!
  4. tewlman
    tewlman
    343
    9
    Nov 24, 2003
    if you screw up i have an axle housing i might be able to part ways with.
  5. KS
    KS
    31
    May 9, 2003
    Ive cut just like the picture, down the center of the old weld. I did grind the old weld off. Seems like its close to 1/4'' and I cant see A seem. I cut 3/8'' from outer edge of weld. I might not be quite deep enough. I dont want to ruin my axle. Thanks for the info.
  6. Isotel
    Isotel
    4,061
    Media:
    5
    Albums:
    1
    39
    Sep 29, 2003
    Crawlorado.com
    its possible you areent far enughf away from the weld
  7. Eskimo
    Eskimo SILVER Star
    1,358
    Sep 6, 2002
    Danville, PA
    Whack the housing with a BFH several times, and the crack will magically appear.
  8. dinkleberry
    dinkleberry
    303
    1
    May 15, 2003
    Vermont
    [quote author=Eskimo link=board=1;threadid=12511;start=msg115021#msg115021 date=1078424585]
    [/quote]
    I had an exgirlfriend like that! :slap:
  9. KS
    KS
    31
    May 9, 2003
    Thanks for the input guys. I finished my cut and turn today. Wanting for the knuckle rebuild kit so I can put on disc brakes. Thanks,Kevin
