My light came on recently on my 92 FJ80. Autozone here says they can only get codes from American cars. I ask y'all because my old 1995 M3 would let me do a trick with the gas pedal to get the code. I did search but came up with nothing helpful. thanks
Yes you can read the codes. YOu need to jump 2 of the terminals on the diagnostic plug under the hood(passanger side firewall) then you count the check light flashes and compare them to the codes in the FSM. I don't have my manual handy to tell you which 2 terminals to jump(us a paper clip)
How do you retrieve the codes on a 95? My manual says that the paperclip trick only works through 94, and Autozone here says they can only scan 96 and up with OBDII. I understood the 95 had OBDII, but it doesn't have the port under the steering wheel.
95 has both 'cause they are the coolest. 8)
Autozone is wrong. I pull codes with the scan tool all of the time. In fact, now I have a new one - low catalyst efficiency. Some bone head banged a bunch of rocks against the cats and then dunked 'em in the water. Now they're all rattly inside.
Bill,
With the engine off and the key removed, raise the bonnet and locate the fuse box just behind the battery. Locate the EFI fuse and remove it for about 30 seconds. Put it back in, close the bonnet, and start the vehicle.
The MIL should be cleared and you will likely have a rough running vehicle with an abnormal idle for a while. It could take several start/stop cycles for the engine to smooth out. Be assured that it will, as the ECU is relearning and remapping values.
The alternative is to remove the negative terminal on the battery. If you go this route then be sure that you know your radio code (if set) before you disconnect the battery.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
