how can i edit my startup programs in XP?
Discussion in 'Chit-Chat' started by erics_bruisers, Aug 10, 2005.
  1. erics_bruisers
    erics_bruisers
    2,032
    2
    Mar 28, 2003
    there's no "startup" folder any more under programs --
    -- i heart MS --
    thanks!
    e
  2. freightdog
    freightdog
    861
    54
    Nov 6, 2004
    Lodge Grass, Montana
  3. Jomama
    Jomama
    590
    Media:
    8
    Albums:
    2
    346
    Jun 4, 2003
    Anchorage AK
    Go to "Start"---> "Run" and type MSCONFIG... Will give you a checkable autoexe window...
  4. jwest
    jwest
    688
    1
    Mar 12, 2004
    If you want to do a selective startup, use the startup configuration utility.
    start->run-> (and then type) msconfig
    The last tab has your startup programs.
  5. erics_bruisers
    erics_bruisers
    2,032
    2
    Mar 28, 2003
    thak you for this all --
    -- DAYUM, was there ever some JUNK in the TRUNK -- !!
    :D
    e
  6. jwest
    jwest
    688
    1
    Mar 12, 2004
    You can also drag and drop a shortcut of any program into your startup folder.
    XP has one too.
    It's under your main drive letter -> documents and settings -> your profile -> start menu -> programs -> startup.
    Just put a shortcut there and it'll be open on bootup.
  7. chitown40
    chitown40
    2,109
    22
    Feb 9, 2004
    Buffalo Grove, IL
    And the other stuff that is not in the startup folder can be found in the registry under HKEY_LOCAL_MACHINE/SOFTWARE/Microsoft/Windows/CurrentVerison/Run
    Often times this is where Spyware will be called from upon startup. Also stuff like your virus scan and other utilities are called from here. Use 'regedit' from the Start-->Run--> prompt to edit the registry. MAKE A BACKUP first.
  8. erics_bruisers
    erics_bruisers
    2,032
    2
    Mar 28, 2003
    thanks for this, chi -- will look at it too --
    :D
    e
  9. nyk438
    nyk438
    253
    Jun 23, 2005
    Austin, TX
    Beat me to it :flipoff2:
