- Location
- United States
I have been on edge about selling my Land Cruiser. Today, I feel as if it’s time to part ways. I have owned this 80 series for quite sometime and have put much effort into what it is today. She is a rare locked 1996 Moon Glow Blue Pearl that is tastefully modded to take any course of action when trailing, over-landing, and rock climbing. I have taken her around the states and performs as it should. Absolutely no hiccups and has never left me and my family stranded. Paint is all original with cuts and bruises. I bought the vehicle with inspiring intentions to build around Adams Box Rocket. She currently has 330k, and has had some substantial head work done at 300k, only for the sake of its value, which these cars deserves. Below I will list the modifications performed by myself, and other reputable shops here in Houston.
I have priced the vehicle to my best knowledge of what it’s worth, followed by the modifications incurred during my ownership. Thanks for any interests and hope she goes to a new well deserved home.
*1996 Model Year
*330K Miles
*Moonglow Blue Pearl
*OEM Locking Differentials
*$22,500 OBO
Interior/Audio:
-Kenwood DDX9703S Double Din
-JL 10TW3
-JL JX500/1D Amp
-Custom Built to Spec Enclosed Box
-BH3D Double Cup Holder
-Ultragauge II OBD2 Scanner Tool
-Cobra 19DXIV CB Radio
-LED Interior Bulbs
-USB Adaptor
-Wits End Console Liner Kit
-Wits End Center Console APU-2 Accessory Kit
Exterior/Drivetrain:
-Overland Member #1855
-New Fender Gasket
-Working Antenna
-DEPO Side Mirrors (still have color match set)
-LED bulbs
-Labs Front Bumper (Personally Welded & Power coated)
-Labs Rear Basic Bumper (Personally Welded & Power coated)
-Custom Bilt Rock Sliders
-Smittybilt 9K Winch
-Smittybilt Synthetic Line
-Factory55 Fairlead
-Factory55 Prolink
-Safari Snorkel
-ARB Breather Kit
-OME L Shocks
-OME J Springs
-OME Steering Stabilizer
-Front Bump Stops 1"
-Rear Bump Stops 2.5"
-Slee Sway Bar Drop Kit
-Metal Tech 1.5" Spring Spacer
-SleeCaster Plates
-Slee Tie Rod
-Slee Drag Link
-Slee FR/RRAdjustable Panhards
-555 Tie Rod Ends
-Nitro 5.29 Gear Set with Master Install Kit
-Solid Pinion Spacers
-Ultimate CV Axle Set 30 Spline 300M Shaft Upgrade
-Front Double Cardin Driveshaft
-Rear Double Cardin Driveshaft
-Complete FR/RR Knuckle Rebuild with Koyo Bearings, new seals, diff fluid/grease.
-ARP Knuckle & Hub Stud Kit
-Nord Lock Securing Washer System
Wheels/Brakes:
-Stealth Custom F5’s / 17x9 -38 offset 3.5” Back Space
-37s Mickey Thompson’s BAJA MT
-DBA Slotted Front Rotors
-Stoptech Slotted Rear Rotors
-Man-a-Fre Extended Brake Like Kit
Motor:
-Full Head Work (3 angle valve job) 300K
-Head gasket 300K
-Water pump 300K
-Plugs 300K
-Ignition Wires 300K
-Cap/Rotor 300K
-Wits End Belt Kit
-Wits End Idler Pulley
-Radiator
-Power Steering Pump (not installed) includes lines
-Blue Clutch Fan Mod
-12” Cooling Fan
-Optima Yellow Top
-Hella Deep Tone Horns
-Magna Flow Muffler
-Wits End Exhaust Bushing Kit
Flaws:
-Rear main seal will need replacing
-Power steering pump will need replacing (new in hand)
-Driver seat spider gear will need replacing (common)
-Driver headlight has a rock chip (condensates)
-Seats have cracks/wear (no tears)
-Paint has scratches from trees and brushes
-Small nickel size dents on the trunk hatch
-Windshield has rock chips
I’ve spent a lot of time and money into my Land Cruiser and I’m sure I’m forgetting some stuff. I will entertain any offers close to my asking price. Low ballers will be acknowledged but ignored. Cheers!
*1996 Model Year
*330K Miles
*$22,500 OBO
Interior/Audio:
-JL 10TW3
-JL JX500/1D Amp
-LED Interior Bulbs
-USB Adaptor
-New Fender Gasket
-Working Antenna
-LED bulbs
-Factory55 Fairlead
-Factory55 Prolink
-Safari Snorkel
-ARB Breather Kit
-OME L Shocks
-OME J Springs
-SleeCaster Plates
-Slee Tie Rod
-Slee Drag Link
-555 Tie Rod Ends
Wheels/Brakes:
Motor:
-Head gasket 300K
-Water pump 300K
-Plugs 300K
-Cap/Rotor 300K
-Wits End Belt Kit
-Radiator
-12” Cooling Fan
-Optima Yellow Top
-Magna Flow Muffler
Flaws:
