Are there any HVAC guys on this forum? I'm considering buying a tankless hot water heater to replace an old rusting out unit. Does anybody know anything about them? Good or bad?
MaddBaggins said:Check out www.rinnai.us for some info
I work for Ferguson enterprises, the countries largest plumbing distributor. We sell a ton of these units down here in Tucson.
You need 120v household outlet
3/4" gas line
They are a little pricey but the price on tanked heaters has doubled in the last 4 years, making these a bit more attractive.
I've researched and sold a number of different brands and I think this one is the best in the U.S. When my heater starts to poop out I will be going with one of these.
If you want you can call me at work M-F 6am to 3:30pm MST 520-795-0296
I can answer some questions for you.
89s rule said:I used to work at a plumbing supply house. We had people ask about tankless units alot. We always told them they were crap, had several plumbers install some and custermers were not happy. You have to look at the entire picture. Amp draw, temp rise of the water, GPM output! etc. GPM usually is what kills you. If you have a jaccuzi tub or anything that takes a good bit of hot water then the heater wont be able to fill it and if it will it will take forever!
The companies will tell you that they can get them to work for your application, you just need to piggy back 2 or 3 or 4 together, then you got to figure how much $ will you really save when you habve to spend that much on the heater(s).
Hope this helps some.
LukeZero said:Watch your water quality.... in our area of the country we have a lot of hard water... we have seen the small passageways internal to the heaters get clogged with minerals...sometimes so badly they can't be cleaned with acid. At this point we have several Bosch Aquastars installed, several Steibel-Eltron electrics and we're watching them all carefully to make sure they perform the way the customer expects. We are authorized to sell the Rinnai- but haven't found the correct application to try one yet.
Luke Lefever
Lefever Plumbing & Heating, Inc
Elkhart, IN
el_diabolico said:If I may ask, why do you want to go tankless? Do you want "instant" hot? THere are many ways to accomplish this.
