Would love to get the details on those gauges!
Yes, those are sweet!
Brake pedal is in the center position of three, it can be moved 1" to the left or right and also about 1" closer to the driver. Gas pedal pivots on a spline and can also be adjusted up and down, on an arc.
Engine ECU mounted below and to the right of the glove box. The three connectors are large and difficult to get through the hole in the fire wall.
NCFJ, this is yet another awesome build from you and I don't want to hijack this thread, but can you please share the P/N or supplier of this hot rod oil pan you used? My LS swap went pretty well, but I've already cracked the oil pan on my Vortec thanks to the front pinion ring. There are a lot of oil pans that seem to fill the bill here but yours seems proven. I can read the p/n on the original crate pan but not on the hot rod. Thanks in advance!A view of an LS3 you don't often see. LS3 and hot rod pan. HR pan provides clearance required for front axle.
