THanks for the info ya'll have given me and the info you will be giving me here
I've got an '86 fj60 and it's having some problems
1: She runs really hot. On any long drives I regularly have to stop to add coolant and drive with the heater on full. I have found that I an leaking from my the weep hole on the water pump and will need to replace it. After replacing the pump, are there any other relatively inexpensive things i can do to make her not over heat?
2: The speedometer cluster has died a couple of hours ago. What should I look at first to determine what is wrong. and what is the likely culprit?
3: I saw an ac conversion kit to make elderly ac run with r-134 coolant. It was really cheap. It had the lube, new o-rings and brass fittings. Does anyone have experience with this type of kit? and does it work?
Thanks everyone
Thanks everyone
