I have a DeWalt air compressor that I use for construction/air nailers and occasional air wrenches. From the factory the cut in & cut out PSI was 100 & 125. My framing nailer likes to run at 120 in old lumber, laminated stuff,etc. so that meant a lot of sinking nails with the hammer since it doesn't start charging again until the pressure drops to 100.
Well, upon closer inspection of one of the warning labels it says something about "tampering with factory settings can cause injury...", so of course I have to take it apart. Under the cover for the ON & OFF switch, there was a diagram that showed which screw to turn to adjust the cut in/cut out PSI. Now it fills the tank to 155 and cuts back in around 130. I could turn the screw further, but it looked like the pressure relief valve kicks in at 165. All of the parts on the unit are rated well above that, so I shouldn't have any probs.
Now my nail gun will never see less PSI than it wants, and I have more charge in the tank for the impact wrench.
Just thought I would pass it on, as I'm sure other brand's switches can be similarly modified.
