Same situation here as FJ1969 my '78 never gets more than half. Typically between 1/3 and 1/2 no more. Burp out air....
as others have suggested... burp the air out of the cooling system, before you change anything.
Air in the cooling system makes the engine run hot.
Common after a flush.
There are many links with instructions... this link contains videos
Is there a bleeder valve on the FJ thermostat? I've watched a few videos on how to bleed air and they all reference loosening the bleeder valve when adding coolant at the first step.
How would you do that? I'm assuming remove the temp sensor from the block and just let the fluid wash out? How do you know you got all of it?Your problem may be your guage. If there's air in the system bleed it out through the head.
I usually loosen the temp sensor enough to allow air/coolant to leak out. I do this with the engine running, so I do not remove the sensor.How would you do that? I'm assuming remove the temp sensor from the block and just let the fluid wash out? How do you know you got all of it?
Use infrared thermometer to check throughout head, radiator, etc
