Hot Air Intake Engine Location
There's supposed to be a heat shield bolted to the front of the manifold with a tube pointing up, straight below the HAI. In your case it sounds like it's stuck open.
I've made a couple of these from sheet metal and even aluminum foil and wire to get past the smog man.
A good pic, but it's from a minitruck 22re:
attachment.php
Some 2f pics:
And the unobtanium part you want:
attachment.php
I replaced that with a plate and fittings that circulated coolant to the intake manifold under the carburetor and worked just fine and more durable. When I installed a header the factory version went away.
