Horn Relay (1 Viewer)
Rockwall, TX
Posting this for my Dad. He has a 1975 FJ-40.
Why would horn relay get hot? Its a new relay, have 2 green & yellow wires & 1 green & red , horn will not blow !!!
Any wisdom I can pass along?
Listen to the relay to hear if it clicks when he disconnects the battery. if it does, check the buttons on the steering wheel, one is stuck.
Check the wiring and make sure its correct.......
green/red = power feed
green/yellow= horn switch/ground
green/white= to horn
horns must have case grounds........
Horn Button
Turns out the horn button was stuck! Thanks for the helping track this problem down.:)
