Any luck forger? Im having almost the exact same issue.
PO didn't have the best memory of the vehicle history, but said the alarm went off once and drained the battery over a long weekend/fried the horns. Replaced the horns. But had to pull the fuse after the horn would stay on.
I replaced the horn relay and no luck. When the fuse is in the fog light turns on, regardless if they are switched on or not. With the fuse back in, the horn is off and as soon as I press It, it stays on until I pull the fuse or disconnect the horn grounds.
I have .24-.26 across legs 1-2 and 12v+ across legs 1-3, which isn't correct per previous posts.
I saw a raw wire dangling under the steering column and thought it was the issue. I pulled the steering column cover and lower dash panel, and it turns out it was from a previous PIAA switch and not connected to the horn in any way. I haven't pulled the steering wheel yet to inspect the switch there as its getting dark outside.
Did anything work?
Did anything work?
