Let the fun begin
Well you can't go wrong with a name like 'Power Probe' that's for sure
Have you double checked that exact adapter fits on our brake reservoirs?
Let the fun begin
Yeah that's a lot of psi for the non pressure side. I've used one of those motive bleeders for years on my Audis. I've rarely gone beyond 10 psi.Yes. It fits the reservoir. You tighten a screw on the top that expands the O-ring seal against the reservoir creating the seal. I will probably put it to use this evening. I still need to go by Wal-Mart and get a gallon of brake fluid.
Also, what's the harm in putting more than 20 psi? Is there concern you will blow the reservoir off the master cylinder? That would be one heck of a mess.
I have one of those and when I use it, I have to jam a stick between the seat and the brake pedal to keep the pedal depressed. Also, keep an eye on the fluid in the thing, as it will go through quite a bit.
