hooking up the starter and ignition wires.
ah, landcruisers dont work if you put different engines in them. ;)
Although we do not manufacture a Ford conversion kit, I'll bet the starter and ignition wiring cant be much different than a Chevy swap. In fact the ignition wiring can not be different since it has little or nothing to do with the actual engine being used. PM me with your mailing address and I'll send you our V8 instruction manual at no charge, it shows all the wiring
Actually, the ignition will be different, depending on the engine year. Ford used breaker points into the '70's and then different configurations of the Duraspark series ignition from the '70's into the early '90's, and then went with the Thick Film Ignition. There are variations in wiring these systems.
An aftermarket ignition is an attractive solution (M.S.D., Mallory, ect.), but I (think?) I understand that these systems are based on the factory set-ups in many instances.
I would I.D. the year engine/ignition and research your findings. Good luck and enjoy the ride!
but I would think all of these systems were fed by the 12V wire coming from the ignition post on the ignition switch. If not, educate me!!!
