Hooking up my th350 need some help (2 Viewers)
Charlotte NC
Look at the pictures and tell me where the manufold vacuum is supposed to connect to the tranny.
To the vacuum modulator
Also, I've read that you're supposed to use a hardline for the tranny vacuum instead of rubber hose/tube because the vacuum can collapse the hose.
1 is the vac modulator.
8 and 9 are cooling lines run them to a cooler.
7 is the kickdown cable run it to the carb throttle bracket.
4 is the dipstick/filler tube.
10 is a vent.
forward of 11 is the shifter linkage.
2, 3, 5, 11 and 12 you don't need to mess with.
