MY CAR IS BONE STOCK i think rebuilt motor within last 100,000 miles (320,000 miles on the car)
hey guys,
i was finally able to get a wideband (hks knock amp) and get it working. the only thing is, the placement of the wideband sensor was a bit tricky. i'm not sure how much of an effect it will have on the readings. but i had to put it AFTER the first CATALYTIC converter (just before the muffler).
because the stock header/manifold are 6 into 2 and 2 pipes go into the CAT and then it merges into one AFTER the CAT.
so these readings SHOULD read LEANER than if i were to put it BEFORE the CAT. how much leaner, i am not sure...
anyway, what i got was:
idle: 13.6-13.9
(sometime it would go down into the 12's- i think i have a vacuum issue because the car would stall SOMETIME when i come to a stop/idle)
cruise: 14.2-14.7 (this was anywhere between 5 mph and 70 mph)
WOT (wide open throttle): it went down into the 12's and 11's and MAYBE some 10's.. as the RPM went past 5000 rpm.
second step that i plan on doing if possible is to get a PIGGY BACK fuel controller (apex'i s-afc2) and lean out the idle to: 15:1
and also lean the cruise out to mid 15's.
i won't touch the wide open throttle because i hardly ever do so.
but before all that, i'm planning to look for and fix the vacuum leak. see what it changs on the readings especially at idle.
then change to new plugs... then do the fuel changes... i'll record my MPG and also A/F ratio's each time i make these changes and post back up here.
as of now i'm getting an average of ~14 MPG overall per tank of gas. roughy ~300 miles per 21-22 gallons with where it sits right now.
i was hoping that it would read really rich and so i could have more room to work with!
having a landcruiser that gets 18-20 mpg would be INCREDIBLE
hey guys,
idle: 13.6-13.9
