Homemade snorkels ideas
I haven't attempted these on my truck but, i have seen a piece of corrigated drainage pipe and a piece of PVC pipe as snorkles on jeeps.
We've made about half a dozen snorkels basically identical to the one in that link. They're as strong or stronger than the Safari snorkel, and flow better. They are easily removable for thick brush concerns. I have seen several Safari snorkels loose their tops in thick alders, so convienient removal can be important (the Safari tops come off easily too).
And as Jeff mentions on that page... They're CHEAP. Very functional too.
We've field proven them in a number of different situations, including the thick brush alredy mentioned and plenty of deep water crossings.
Metal tubing (exhaust or otherwise) is a good choice too. But more expensive than a few sections of plastic drainpipe.
Mark...
I get grief everytime I post this for link for inlet hood, filters and pre-cleaners, but here it is.
http://shop.airflowonline.com/Merchant2/merchant.mv
I get my intake filters for my Ford PSD there and they have about the prices I've found. If you're looking for a pre-cleaner or anything check'em out. No affiliation just a satisified customer.
:flamingo:
find the piece for the carb ( assuming v8 4bbl. ) off a junkyard newer fi chevy ( they fit if they fit the tbi motor and the air box is remote so it is just the housing at the tbi you want then scavange different turbo hard and soft pipes off the junkers and you can piece togehter a reaslly durable water tight system that looks better than pvc
That said exhaust tubing is another option...
This is the route i'm goin'. I never liked the snorkel coming out the side, so I'm taking mine back thru the cowl & up, just below the windshield, in the middle, to the top of the windshield. I'll get the angled pieces from JC Whitney & have a local muffler shop swage the ends, so I can bolt it together. I've decided I don't want any plastic pieces on this unit, so I'll be fabbin' up both the carb enclosure & the air inlet. Pics will be posted when I'm done.......
It sounds like you are going to route your snorkle up the middle of your rig??? In the middle of the windshield??? Please tell me that's not correct.
Mark...
Well, it sounded good & easy but after rethinkin' it, I would be better goin' thru the side. I just don't like thin walled steel or plastic stuff hangin' off the side of my truck. I think I'll just up the guage of steel & make the inlet a little more durable.
here's mine...The "Home Depot" special...
From the looks of your paint, you haven't had any encounters with trees or rocks. Is that a trail truck or dd? What material did you use to construct it? How durable do you think it is? Do you think think it would get smashed easily?
It is my trail/DD...;)
If you are in the Georgia cruisers, you may recognize this pig...it's Dan Kunz old 55...he originally put the Snorkle on there, I had to rebuild a bit of it. It's been freshly repainted ;) for this season...it took a few good whacks and beat it around. It's made with a dryer vent top (the main part that breaks...i would rather that bust off than rip the whole thing off. The rest is of the plumbing style PVC pipe...definitely thick enough to take a hit. The "plumbed" ;) into the 2F airbox...seems pretty sturdy to me, doesn't seem to get in the way.
older pic...
older pic...
Hey where did you get that bent piece of pipe for your fuel line? Are you using the return line or did you cap it off? What size nut did you use if you did cap off the return line. Thanks.
Travis
Travis
Not sure on the piece, it was there...the return is hooked up on mine, visible if you look at the filter up by the oil filler you can see that line. So yes, I'm NO help at all...lol :doh:
And yup, his old cruiser made it to Colorful colorado...it went to idaho first, and now I've had "Pig" for over a year...put quite a few mods on her...4 wheel discs, dual ARB's, 35's, Power steering, Krylon paint ;) next year....BODY WORK!!!! and new paint...(real paint) lol
Guess i'll have to do some Home Depot shopping then. Does your return line go back to your gas tank? I have a 76 body but a 79 2f. There is a hose cap on my fuel pump... I wonder if the return line goes back there?
I have a similar setup on both my 55s, though there is no flex tubing outside of the truck. One was built by me, the other the PO. Both are pretty durable; other than head issues, I've taken both down some tight trails and the ABS has come out unscathed. I haven't laid the truck on it's side. I think you could break it depending on what you rolled onto. Otherwise, both have brushed off 2" alder type of branches, and a 5" tree fell on one. No big deal. The mount just needs to be strong.
The head is the weakest point, and that's up to you. The one pictured is made from metal, and a wing nut on the back keeps it from comming off. loosen the wingnut, flip it around, and trees aren't too much of a problem. (edit- the grey thing above it is a shovel on the rack.)
