hi guys i have access to a parts 60 i was thinking of stripping the main leaves from each spring pack and cutting them to make full length add a leaves ? any one think this is a good or bad idea ? also i am going to make my own shackles and was planning on adding a grease fitting where should the grease nipple(S) go . i was planning to use 3/16 " thick steel and new grade 8 bolts , i have a 80 amp mig welder and access to a 220 amp stick . i recently welded a new rear shock tube in place and so far so good . i was thinking about shackles with about 6 " eye to eye ? how much lift do you think this combo would give i would them get the toyota 16 " rims and add some new meats about 32" ers
i am guessing i should get about 3 to 4 inches .
thanks for the feed back .
