holley 4 bbl 600 cfm on 2f
Lutz, FL
My dads 82 has a holley 4160 carb on it 600 cfm. It also has the offy manifold, it is certainly quicker than the avg 2f but is running too rich. Can I get this thing to tune correctly or would it be best to swap an aisin? For the record mpg seems fine, and this carb was the previous owners work.
Thanks
2F = 4.2L. At 4000 rpm that is about 593 cfm. I know what I would do.
I think he's agreeing with you on your choice to go stock.
If you're not subject to smog checks, you could put a little bit hotter cam in it. If you have a header you could get some pretty good performance out of it on the street. It's always going to suck on steep inclines and declines.
I happen to have such a cam. Send a PM if you want it. It was made by Iskendarian specifically for this carb and manifold combination. You could also shave the head a little and run 91 or 93 octane.
Not looking to do engine work...just want it ruining well
Thanks
