Martin White said:
Do you figure POR 15 is the best product going for underbody painting? I'm hoping to keep my HDJ81 looking clean underneath and asked a q. on this on the 80 forum, but only got one response. Is there a supplier for POR in Canada?
If you have somewhat intact factory paint (like a southern USA cruiser, or most of the JDMs coming over) on a good frame, I would be inclined to simply use some good wax oils on the inside, and spray-bomb the outside every year, and keep the frame clean. Make sure the frame is cleaned out on the inside before spraying the crap out of it with a wax oil. In a high salt area I would coat the entire outside of the frame (and underside of the body, crevases, wheelwells, etc) with a wax oil too.
If I had a frame off a truck I would be inclined to have it dipped and zinced.
If I was not going to that extreme I would either blast or clean really well, then treat with a light etch/phoshpate, then use something like POR. I used POR on much of the underside metal (fuel tank, shields, etc) on my BJ42 when frame off'd in 1999. It seems to be holding up well, however it has not been winter driven the last few years.
POR is great if you have complete access, have cleaned and prepped the metal per their instructions. If you have not, then POR will pull off in sheets, or worst case is simply stay intact in place over the metal, but not adhered to the metal...which will allow the rust demons to do their dirty deed.
If you can spray, then something like Endura over a two part epoxy primer is worlds above what went on the Cruiser frames years ago.
Prep is everything. It is hard to completely prep and clean on the truck imo.
hth's
gb
